AC Compressor not kicking on
Old Mar 30, 2010 | 01:52 AM
acavill's Avatar
acavill is on a distinguished road
Default AC Compressor not kicking on
This was my own stupidity but I'd like to get the problem fixed. About a year ago my battery died and when I went to jump it I hooked the jumper cables up backwards. (positive to negative and negative to positive) . I was gonna be late for work and was in a huge hurry...wasn't thinking to clear. I know that it could potentially be a huge problem (crossing the cables) but thankfully I was pretty lucky. Now that summer is coming I'd like to have my AC working again.
Anyways, when I did that I blew a few fuses...got them all replaced and everything worked perfect except for the AC. When I try to run the AC, the compressor won't kick on.
What I'm wondering is could the compressor be fried? Seems more like a relay somewhere or an inline fuse, but I could be wrong. I tried switching the relay in the fuse box under the hood with a different one, that didn't help. Also there is a 10A fuse in the fuse box that blows everytime I try to run the AC. Tried replacing that with a 15A fuse and it didn't blow but the comp. still didn't work.
Oh and the AC worked perfect when I bought the truck blew ice cold up until I screwed it up.
Any input would be greatly appreciated. Thanks
Old Mar 30, 2010 | 06:56 AM
What happens if you supply power and ground directly to the A/C compressor clutch using a fused jumper wire on the positive lead? Did you check the wiring under the fuse box for signs of damage from the short circuit?
Old Mar 30, 2010 | 09:24 AM
butterflydreams's Avatar
butterflydreams is on a distinguished road
The a/c cutoff switch may have been tripped. It's easy to replace.
Old Apr 3, 2010 | 05:19 PM
acavill's Avatar
I haven't tried either of these but I'll check both. I didn't even think about trying that. Thanks.
RomanKoch
Aug 11, 2013 03:09 PM
ssmith5399@nc.rr.com
Apr 8, 2012 11:05 PM
gmcjimmy_94
Dec 30, 2010 12:37 AM
mahplane
Dec 29, 2006 07:34 PM
MusicMaverick
Feb 13, 2006 02:40 PM
