ac not working
Old Mar 21, 2011 | 05:19 PM
stlwaco's Avatar
stlwaco is on a distinguished road
Default ac not working
2003 BlaZeR2
I have the wiring diagram. I checked fuses. All seem good. pulled the AC relay out a little so the posts were showing. Had 12v at 3 posts but not the third. Bad relay?
I ran a jumper wire from BAT+ to the green wire at the compressor clutch. Clutch activated. Left it there for a couple minutes. Didn't really seem to get cool in the truck. I would rather not have to spend $$$$ on freon if it is not needed.
Old Mar 21, 2011 | 07:27 PM
84BlazerS10's Avatar
If it doesn't get very cool you probably need to check the refrigerant charge and if it is low enough it will cause the compressor to kick on and off.
If the system is overcharged it will also reduce it's cooling ability.
Old Mar 22, 2011 | 12:05 PM
stlwaco's Avatar
Well today I swapped the ac relay with the horn relay. I wish I could say that fixed the issue.
A neighbor came out while I was working on it. Turns out he has a low side gauge. Hooked up and saw that it was really low. Threw a couple cans of 134 in it and now it works great. However, when I pulled the gauge off after topping it off, I noticed bubbling in the low side port. Looks like I found the leak. Is the schrader valve replaceable by itself or do I need to replace the whole accumulator? For now, Im just leaking the gauge on it (since I can get it to seal) until I can get the leak fixed.
Old Mar 22, 2011 | 06:21 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
did you use the R134 with sealer in it ? maybe that will take car of it for now if you did
Old Mar 22, 2011 | 09:20 PM
I'm not sure specifically but I think you would have to replace the whole accumulator.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
bootlegger
Dec 14, 2010 05:18 PM
218persuader
Aug 20, 2010 06:11 PM
chrisblaze
Dec 6, 2009 12:27 AM
