Actuator removal
Old May 8, 2017 | 07:15 PM
WinnipegsonomaZR2's Avatar
WinnipegsonomaZR2 is on a distinguished road
Default Actuator removal
Has anyone pulled off the actuator that has the yellow and brown vacuum lines connected to it......is there a clip or just pull up my panties and pull on it....I have been at it for hours trying to figure how to get it off.....any help would be greatly appreciated... I have pulled all the trim panels off and is up in a tight corner just able to get my hand around it.... I think I can feel what seems like a clip but I can't see it and is almost impossible for me to push on it and pull on the actuator at the same time
Old May 12, 2017 | 07:37 AM
LannyL81's Avatar
Might try using a small mirror to help see. I have not removed this nor have I read about anyone doing so. Curious, why are you wanting to remove it?
Old May 15, 2017 | 04:15 PM
There isn't even enough room for a small mirror.....so I went back at it determined to get it off and after my morning coffee I went in and got her done!!! As u can see there is a clip and with the help of a small screwdriver ( and some luck) I got it out......why u ask....My Vent air would always blow in my face and I couldn't change it to defrost..... so after taking all my trim panels off and dropping the glove box I operated my vent control and I noticed that the mode door actuator did not move.....I operated it by hand and I was able to control the vent from defrost to foot so I unhooked the actuator and tried to operate it without the load of the blend door and nothing happened (I checked the vacuum lines with a gauge and had suction) So I'm hoping that the inside diaphragm is shot as I have ordered a new one (of course it's the one that is $55 and all the others are $15) hoping to get the parts I ordered this week and will update my findings
Attached Thumbnails Actuator removal-img_0104.jpg   Actuator removal-img_0105.jpg
Old May 16, 2017 | 09:13 AM
LannyL81's Avatar
Well congrats on getting the actuator off. Easy to test the actuator; just put a finger lightly over the hose connection and then move the arm. If it moves freely, then yep the diaphragm is shot. If you can feel air moving in out of the tube, then it is fine.
Odd though....usually I have read that the problem is not being able to get air flow anywhere but the defrost outlet. This is due to defrost being the default. The usual failure is the defrost valve inside the duct has broken...which is moved by the actuator below the one you removed.
Anyways, yeah, be sure to update.
Good job!!
Old Jun 7, 2017 | 10:07 PM
Well I've been putting it off long enough and today I went out and put my new parts in and with would see if they worked
First I put in a new 4x4 cable in hoping that it was my problem as I was getting vacuum to the 4x4 actuator but wasn't pulling it in all the way. After putting the new one in I quickly found out that it wasn't my problem... after a little more trouble shooting...found out that it's the actuator... I replaced it not that long ago but as the pics show...there was a minor tear just small enough to cause me problems
Second I changed out my blower motor control module/resistor as I read that if my fan was working on some speeds but not others that this could be the problem.....0 for 2......it's the blower motor... but thxs to the great people at Rock Auto it only cost me 12.75 and it's prettier then the old one!!!!
3rd and back to my original post...I replaced my vent actuator.... and FINALLY success....1 for 3.... after putting the new one in I was able to change my vent to defrost and air stopped blowing in my face all the time
So a word of advice to people who have vent problems.... remove all your dash panels (which even after 3 weeks in between removing and install with nothing labled....all went back together good) and watch your actuators to make sure u have the proper movement and if it is the heater blend door that is broken you will have a good start in replacing it
Attached Thumbnails Actuator removal-img_0108.jpg   Actuator removal-img_0109.jpg
Old Jun 7, 2017 | 10:19 PM
Old Jun 7, 2017 | 10:55 PM
Old Jun 9, 2017 | 05:58 AM
FMB42's Avatar
FMB42 is on a distinguished road
Thanks for the info!
Old Nov 24, 2017 | 01:20 PM
John Schoenfelder's Avatar
John Schoenfelder is on a distinguished road
WinnipegsonomaZR2
can you let me know where you were able to order the new actuator. I have looked and can not find a place that carries them. i took a used one off my parts blazer but i would have rather had a new one. Thank you
Old Nov 27, 2017 | 07:51 PM
Originally Posted by John Schoenfelder
WinnipegsonomaZR2
sorry for late response just seen email.....I bought it from Rock Auto
stickemdano
Nov 14, 2009 11:13 AM
markrd
May 8, 2009 01:39 PM
ryansoxfan
Aug 16, 2006 09:23 PM
shanes
May 5, 2006 01:23 PM
Derbytown
Aug 23, 2005 12:00 PM
