aHHHHHHHHHHH HELP ME 98 BLAZER
Old Apr 22, 2013 | 08:59 AM
dynasty314's Avatar
dynasty314 is on a distinguished road
Angry aHHHHHHHHHHH HELP ME 98 BLAZER
changed distributor, plugs,wires,fuel filter,fuel pump,gas and still will not start PLEASE HELP 98 blazer 4.3
Old Apr 22, 2013 | 10:10 AM
Twip's Avatar
try rolling the motor to TDC and then pull the distributor cap and make sure that you have the thing in there right. when at TDC the rotor should be pointing that the plug wire that goes to cylinder one. if it isnt, pull the distributor and re-align everything.
Old Apr 22, 2013 | 10:14 AM
swanman35's Avatar
swanman35 is on a distinguished road
What Twip said, mine wouldn't start until I did that. It took me a few tries though
Old Apr 22, 2013 | 09:06 PM
Do you have spark?
Do you have proper fuel pressure at the test port?
Old Apr 22, 2013 | 10:26 PM
LeWhite's Avatar
There are TWO tdc. Unless its a two stroke. But yeah prolly got the dis ont tooth off.
Old Apr 22, 2013 | 11:27 PM
BresBlazy's Avatar
BresBlazy will become famous soon enough
does it try to start? lights work? explain what happens when you try to start, I mean could be starter or ignition switch issues??? check engine light come on? battery light come on?
Old Apr 23, 2013 | 07:49 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
Is the starter turning it over? Air filter not clogged? Do you have proper fuel pressure(55+)? Do you have spark? Is it in the right order and at the right time? Evidence of fuel spraying? If all these can be answered yes then it should run
Old Apr 28, 2013 | 09:07 AM
dynasty314's Avatar
I believe its TDC problem I will check also I have a parasitic battery drain soon as you turn the key it dies even if u jump the battery it dies
