Air Cond. Problem
First time using this.......so bear with me please. I have a 1997 Trailblazer and the check engine light came on. The next day the air cond. stopped working......it will not blow air out of the vents, but I can hear air blowing .The rear air works fine though. Do you have ANY idea what would cause this? I would really like to try to fix myself before spending a ton of money, and was in the process of trying to sell. (how conveninant it would happen when it did) [sm=headbang.gif]
First thing's first, they did not build a trailblazer in 1997. Second, the first OR second generation s/t utilitys did not have a rear blower. I will assume that you have a 2002 or newer Trailblazer (3rd generation s/t utility) and also that it is an EXT model, because they are the ONLY s/t trucks EVER built with a rear a/c unit. You need to first check and make sure the compressor clutch is engauging when you request a/c operation. It should be if the rear unit is cold. If so, you probably have a restricted orifice tube, that's about the only thing that can cause the front a/c to blow warm and the rear cold, except a temerature door not switching to the cold side.
nuwave
Feb 10, 2011 01:28 PM
jojocarreno
Jul 1, 2010 07:30 PM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
arthurmott
Mar 29, 2006 01:21 AM
