Air flow minimal only in hot position
I have a lot of heat going throught the heater core on my 95 jimmy, the problem is when I go from cold to hot the air flow decreases dramatically. The blower fan is new. Is there something I can pour down to clean the air side of the heater core?
Thanks
Thanks
Hmmmm .. leaves?
Thought. Remove blower if easy. Set for air out to easily accessible ducts. Block ones you cant get to. Slick leaf blower or High power shop vac to duct to reverse flush the debris
I was thinking the same thing. I have a shop vac and will try reverse flowair to see if will blow anything out. Thanks for your reply pettyfog.
nuwave
02-10-2011 01:28 PM
gmcjimmy_94
01-23-2011 09:11 PM
ravenhurst
15
04-26-2009 07:53 AM
dimmuborgir6nik6
10-02-2008 06:51 AM
