Air in Fuel System
Old Apr 16, 2013 | 07:48 PM
Cephkiller's Avatar
Cephkiller is on a distinguished road
I was able to test the pressure this evening.
  • Key ON - 65 psi
  • Pressure drops to 0 psi immediately after pump stops running
  • Engine Running - 55 psi
Old Apr 16, 2013 | 08:17 PM
Pressure is fine but leakdown is excessive. Next step is to find out where it's leaking. The filter is on the frame rail, driver side. There is a black plastic quick connect fitting that needs to be disconnected from the filter. You will need to modify the fuel pressure tester so that it connects directly to the fuel filter outlet, (with no leaks). All fuel pressure and flow must end at the tester. When the pump is running, pressure must be 73psi to 108psi. It must remain above 55psi for at least 10 minutes after the pump shuts off. The results will tell where the leak is. Post your results.
Old Apr 17, 2013 | 07:14 AM
Cephkiller's Avatar
Thanks! I'll post the new data within the next few days.
Old Apr 17, 2013 | 07:26 AM
LannyL81's Avatar
My bet would be the fuel pressure regulator is shot and the intake plenum is going to have lots of fuel puddles.
But need to complete the testing first and foremost.
Blueline
Oct 4, 2013 12:09 PM
liltittle62
Dec 26, 2010 03:55 PM
sparky672
Oct 11, 2010 09:42 PM
Logster1
Jul 7, 2009 02:31 AM
98SmokeBlazer
Mar 1, 2008 08:38 AM
