air vents
Old May 28, 2010 | 12:02 AM
daddyb1's Avatar
daddyb1 is on a distinguished road
Default air vents
Air will blow from all vents (floor, defrost) except the center vents i dont know why. Help. I checked the vacume at the control switch and it seems fine
Old May 30, 2010 | 03:47 PM
95 blazer 4x4's Avatar
95 blazer 4x4 is on a distinguished road
I'm having the exact same problem with mine now, how do you fix it?
Old Jun 1, 2010 | 08:05 AM
vanaman's Avatar
vanaman is on a distinguished road
I had the same problem on my 95 Blazer, the PCV valve was bad. My mechanic claims the vents get the vacuum source from the PCV valve and if it goes bad anything else vacuum operated will not work correctly.
Old Jun 1, 2010 | 11:21 AM
If the vacuum to the control switch in the dash is "fine" (i.e. measures the same or close to the same as idle vacuum on the motor, then the vacuum system is operating properly.
To the OP, please provide your vehicle information.
Old Jun 15, 2010 | 12:40 PM
Wholeo's Avatar
Wholeo is on a distinguished road
I have the same issue. Not sure when it started. I can position the switch to vent or AC, and the air only flows out of the defrost vents and floor vents. Other than the PCV Valve, what else could be the issue?
scoot
Jan 8, 2007 08:48 PM
flipster125
Oct 27, 2006 01:37 AM
ItradeNDX
Feb 3, 2006 05:21 PM
ron36535
Feb 3, 2006 05:14 PM
ron36535
Dec 28, 2005 04:05 PM
