Airbag light B1061
Old Apr 27, 2014 | 09:08 PM
RandyRhoadsFan82's Avatar
RandyRhoadsFan82 is on a distinguished road
Default Airbag light B1061
hey guys I have an airbag light on and I read the code its a B1061 and to my surprise, with the search button, its a new one on here!
In the RUN position, the ignition switch applies battery voltage to the AIR BAG warning lamp and to the IGNITION POSITIVE VOLTAGE input terminal 10. The inflatable restraint Sensing and Diagnostic Module (SDM) responds by flashing the AIR BAG warning lamp seven times. The SDM monitors the lamp driver output by comparing the output state at the SIR INDICATOR terminal 7 to the microprocessor commanded state.
Conditions for Setting the DTC
The output state at the SIR INDICATOR terminal 7 does not match the commanded state of the lamp driver for 400 milliseconds.
The CONTINUOUS MONITORING test checks for this DTC. This test occurs when IGNITION 1 is within the normal operating voltage range.
Action Taken When the DTC Sets
• The SDM sets a diagnostic trouble code.
• The SDM attempts to turn on the AIR BAG warning lamp.
Conditions for Clearing the DTC
• Current DTC
The output state at the SIR INDICATOR terminal 7 matches the commanded state of the lamp driver for 400 milliseconds.
• History DTC
- You issue a scan tool CLEAR CODES command.
- 250 ignition cycles have occurred without a malfunction.
Where in the world do I start to fix this?
Old Apr 29, 2014 | 05:23 PM
bump....anybody?
Old May 1, 2014 | 10:41 PM
come on somebody's gotta know!
Jonboy
Mar 12, 2012 07:08 PM
gscrippler
Jun 7, 2009 08:53 PM
aaronjohn20
Mar 21, 2008 07:00 AM
mdehoogh
Aug 10, 2007 07:54 AM
hotrod28
Nov 4, 2006 08:11 PM
