All 4 power windows dead
Old Jan 5, 2021 | 05:09 PM
Leftysdad's Avatar
Leftysdad is on a distinguished road
Default All 4 power windows dead
Hello...
acquired a 96 blazer from my neighbor.....all 4 windows are dead....no clicking or anything....looking for a place to start other than the fuse...thanks in advance!
Old Jan 5, 2021 | 07:46 PM
Drivers side window switch
Old Jan 6, 2021 | 12:01 AM
GeorgeLG's Avatar
Are all 4 windows dead at every switch?
George
Old Jan 6, 2021 | 04:18 AM
Leftysdad's Avatar
Yes they are
Old Jan 6, 2021 | 11:12 AM
GeorgeLG's Avatar
Since all four window switches are dead then you most likely have a power problem. Since it sounds like you already checked the fuse I would get into the drivers door and see if you have power on the yellow wire into the window switch module.
George
Old Jan 11, 2021 | 11:34 AM
puttster's Avatar
You might ne able to lift the switch without removing the whole panel, might be worth a try.
Originally Posted by puttster
Problem solved!!! Acting on a tip seen here on blazerforum I gave the window motor several whacks with a hammer. Connected a battery directly to the motor and zzzipp. Window up, window down. I hope it lasts and though I have a new, now-unnecessary switch (for sale), I am happy.
The most tedious job was detaching and reattaching the switch terminals, which are pinned in by plastic lockers. I'll try to attach a pic that might save someone the time needed to figure it out.
Also if you want to test the window switch, note the power for it comes through the door lock switch, so that needs to be plugged in. For the door panel you'll need a 7mm socket and probably plastic door panel clips the number is GM 10153057.
nitrally
Sep 7, 2012 05:55 PM
Michaelm053
Jul 5, 2012 12:54 PM
dylisa8
May 17, 2010 10:34 PM
luiscazarez
Jul 16, 2008 08:23 PM
ajmeehan
Engine & Internal
May 23, 2005 11:41 PM
