ANOTHER heat related question
When the blower is on there is not much air coming out of the two side dash vents - I am assuming that these have a vacuum actuated damper? If so, after I check/replace the vacuum hoses is there anything under the dash that I should look for?
RE: ANOTHER heat related question
Yes, they are vacuum actuated. If repacing the vacuum lines didn't fix the problem post up. There are vacuum lines in the dash and connect to the control switch on the dash.
Check here
This thread includes a schemataic of HVAC vacuum system.Heater help - vacuum
All thanks to Kyle for provide the information in the linked thread.
jaxteller
05-02-2014 01:07 PM
chrishorton74
06-02-2010 09:03 PM
GimmieBoost
02-26-2007 10:37 PM
BlazerRJM
22
12-04-2006 04:20 PM
