another hvac question
Old Apr 1, 2015 | 08:30 PM
  #41
Does it leak out of another port? If so, which one?
Old Apr 1, 2015 | 08:38 PM
  #42
er0ck273's Avatar
er0ck273 is on a distinguished road
it leaks out of number 3, not sure of color since dash is back together. but if your looking at a back view of the mode switch, its at the 9 oclock position on the inside of the two
Old Apr 1, 2015 | 09:04 PM
  #43
In the vacuum connector at the mode switch, connect the vacuum pump to the red vacuum line, apply vacuum and see if it holds.
Old Apr 1, 2015 | 09:13 PM
  #44
er0ck273's Avatar
what mode is it on when i do this?
Old Apr 1, 2015 | 09:50 PM
  #45
In the connector, with the mode switch unplugged.
Old Apr 1, 2015 | 09:56 PM
  #46
er0ck273's Avatar
gotcha! Will probably be done tmr night or friday. Originally when i tested the colored lines only yellow and brown had the slow leak and red blue orange tested fine, but i will double check red line again
Old Apr 2, 2015 | 02:56 PM
  #47
er0ck273's Avatar
Red tested fine, if anything it dropped less than a quarter but i could be going senile at this rate haha....
This morning i had time to test it again....both on ac and then heat for every mode....max ac ac and bi level worked perfectly, only a small amount came from defrost vent then when i started driving it didnt come out of defroster...the only thing that didnt work was floor it also came out of defroster but i can live with that i never use foot only....when off is selected....it still comes out of defroster vent
Testing was with old unit too
Old Apr 2, 2015 | 03:59 PM
  #48
er0ck273's Avatar
redid the test on all vacuum lines...heres my results by what number port the color corresponds to (after 10 minutes is second number)
1 Orange 20 -20
2 Red 20-19.5
3 Yellow 20-17
4 Brown 20-20
5 Blue 20-19.75
6 Black 20-20
Old Apr 2, 2015 | 05:06 PM
  #49
OK, that's good. No leaks in the lines or actuators. As you're applying vacuum to each line, make sure each actuator operates its linkage, and the door actually moves.
Old Apr 4, 2015 | 02:06 PM
  #50
er0ck273's Avatar
Here's what I got wheni based on color
Red-vents ( lightly defrost and floor)
Orange- high vents (assuming max ac)
Brown- defrost/floor (light vent)
Yellow- floor (light defrost)
Blue- vents (light defrost and floor)
