another hvac question
Old Apr 13, 2015 | 01:33 PM
  #61
er0ck273's Avatar
er0ck273 is on a distinguished road
Sorry for the constant posts...i just checked the 4wd line from where it connects to the small black T (took t off) to actuator on firewall. Leaked 5 psi over 20 mins...line is fairly new about a year old
Old Apr 13, 2015 | 02:22 PM
  #62
Naa don't need pix. The purpose was to make sure the 4WD was not leaking, and it's not. The reservoir is not leaking either. Back in post #50, did each color hold vacuum AND move the respective doors?
Old Apr 13, 2015 | 02:51 PM
  #63
er0ck273's Avatar
With post 50, when i applied vacuum to each, it did seem to operate the doors properly with tiny bit of ait comin out pf the wrong vents..where mentioned "light". I just took a ride around the block. ...auto 4wd 2hi 4hi and 2low all switched properly. I also checked the line going to 4wd actuator itself by plugging one end and applying vacuum to other..it held vacuum so we can rule that line out
Old Apr 13, 2015 | 05:47 PM
  #64
That's good, but did each color hold vacuum at the mode switch connector, (directly to the vacuum line)?
Old Apr 13, 2015 | 06:16 PM
  #65
er0ck273's Avatar
Yes, the only line that slowly leaked was brown and yellow....but 3psi over 10 minutes but you noted that wasnt anything to worry about
Old Apr 13, 2015 | 06:20 PM
  #66
I'm just double checking here, please humor me
If you connect the vacuum pump directly to the line under the hood that goes directly into the dash, (no check valve, no Tees etc) and apply vacuum, it won't hold vacuum?
Old Apr 13, 2015 | 07:03 PM
  #67
er0ck273's Avatar
on which mode? just off ?
Old Apr 13, 2015 | 07:07 PM
  #68
Check all of them again just for grins, and keep track of the results. Some modes will take some serious sucking to get vacuum down to 20", others will suck down rather quickly.
Old Apr 13, 2015 | 07:15 PM
  #69
er0ck273's Avatar
will double check tmr, it did leak on just the plastic line entering the cabin on off and bi level today, i was trying to trace it down to what was and wasnt
Old Apr 13, 2015 | 07:26 PM
  #70
You have checked all of the vacuum lines at the mode switch connector, and they all checked good, (this also checked the actuators). You checked the plastic line from under the hood to the mode switch connector, and it checked good. If it leaks vacuum on any position when testing from under the hood, the mode switch is definitely the problem.
