Another No start 99 blazer 4.3
Old Jun 14, 2010 | 06:02 PM
quagmire's Avatar
quagmire is on a distinguished road
Default Another No start 99 blazer 4.3
Well it kinda starts for about 5 seconds also runs when fuel is poured down the tb
New parts within the last 2000 miles
fuel pump
fpr
fuel filter 2x
spider o-rings
dizzy
3 o2 sensors
plugs
coil
wires
cap
rotor
It was running fine actually stupendous averaging 19.5 mpg then I came home shut it off and it will start for 3 seconds or so then stalls
I haven't checked the pressure at the rail but, is it that common for the pump which I can hear running to go bad in 3 weeks to a month?
I hate this truck
Old Jun 14, 2010 | 06:45 PM
Don't hate the truck... hate cheap parts. I've had aftermarket pumps fail before leaving my shop, I won't install them anymore, haven't for years. You get what you pay for, Airtex, Master, Bosch, Carter, Autozone, etc... stay away. If you want a quiet, reliable pump, go with AC Delco or Delphi.
Key on, engine off, fuel pump running: fuel pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes after the pump shuts off.
Old Jun 14, 2010 | 07:07 PM
quagmire's Avatar
63 psi key on 60 at crank holding for 15-20 minutes no problem
thanks It has been one headache of a truck that's all
after reading and a bit of digging fumbling etc under the dash I have reason to believe it is the remote start deh555l that is causing my problem
Old Jun 14, 2010 | 07:16 PM
VERY possible for the pump to be erratic. Could be a faulty pump, weak check valve in the pump, your remote start, or even a problem with Passlock shutting off the fuel pump relay. But, if you heard the fuel pump relay, and the pump running, I'd strongly suspect the pump.
Trb
Feb 3, 2015 09:41 PM
chrishorton74
Jun 2, 2010 09:03 PM
firemansc32
15
Oct 20, 2009 10:07 PM
pusher
Jan 5, 2009 08:28 AM
rob2129us
Sep 11, 2008 07:24 PM
