antifreeze smell
Old Nov 21, 2011 | 12:37 PM
A Perry's Avatar
A Perry is on a distinguished road
Default antifreeze smell
Lately anytime I've tried to use the heat in my 98 Blazer a syrupy antifreeze smell consumes the car?? My temp gage is still reading pretty low/normal, and nothing else seems out of the ordinary. What could this be?
Old Nov 21, 2011 | 02:31 PM
DaveHearne's Avatar
DaveHearne is on a distinguished road
Is your coolant level OK? If not you may have a leak from your heater core?
Old Nov 21, 2011 | 02:44 PM
warthogdriver's Avatar
yup, heater core is most likely leaking at the seam and "cooking" off what little seeps out and taa daa...you get your lovely scent.
Old Nov 21, 2011 | 04:16 PM
A Perry's Avatar
Thanks! Would this cause a "smoky cloud" to come out of the air vents when the system is turned off?
Old Nov 21, 2011 | 07:59 PM
could...and a nice fog on glass as well.
Old Nov 21, 2011 | 08:02 PM
xgiovannix12's Avatar
yep you need a heater core my friend =)
you can bypass the hoses but you wont have heat or defrost this winter =(
Old Nov 21, 2011 | 08:51 PM
A Perry's Avatar
I can live without heat or defrost, but is it dangerous to drive otherwise? If I don't run the heat/defrost will that eliminate the smell?
Old Nov 21, 2011 | 09:08 PM
you can bypass the hoses under the hood
and that will prevent the heater core to leak
No heat and defrost sucks trust me ive been threw it
edit: you can use something like this to bypass it
there should be 2 hoses on your firewall on the passenger side
Old Nov 21, 2011 | 09:19 PM
Tubais's Avatar
Tubais is on a distinguished road
the smell won't go away completely and the leak will eventually get larger
Old Nov 22, 2011 | 08:06 AM
i wouldnt use plastic though..it will crack and fail.
use brass.
i take it your i a warmer climate then me...i would be scrambling to fix that bad boy.
i looped mine off on my mustang no issues...summer wheels.
