Any here have a diagram of the grease fittings for a 1999 Blazer LS 2 door?
I checked in my owners manual and also di a quick search on the net to see if i could find a diagram showing all of the grease fitting locations for my 1999 Blazer LS, ZR2
Any here that can post a diagram/drawing of the location of the grease fittings?
I can tell you where they are but i do not know of any diagrams.
These are all of the possible locations, the fittings may not be there if the component has been replaced with an aftermarket one of that design.
1) upper and lower ball joints both sides if the fittings exist they will be on top of the ball joint.
2) inner and outer tie rod ends
3) idler and pitman arm
4) u joints (if replaced with an aftermarket design)
there should be 9 fittings on the front end and up to 4 more possible in the u joint
He has a ZR2 so add one more for the steering stabilizer. And I believe there is only one on the idler arm, at least there is on mine.
You might have two more on the anti-sway bar if aftermarket bushings have been installed.
jimspahr@msn.com
05-03-2014 09:50 AM
midnightbluS10
12-20-2010 11:43 AM
Ugly_Monkey
09-07-2009 02:32 PM
86Blazer4x4
08-02-2009 06:58 PM
