any suggestions with starter
Old Feb 22, 2010 | 08:24 PM
argon929's Avatar
argon929 is on a distinguished road
Default any suggestions with starter
Here's my problem, i got a 99 4d 4x4 this just started today i was sitting in hungry howies parking lot the truck was idleing and the starter kept engaging on its own i shut it off and the starter motor was still running i could hear it then i disconnected the battery for a couple mins hooked batt back up went to start it and i never turned the key over to the start position i only turned the key to where the fuel pump and everything turned on and it started and randomly while driving home the starter kept engaging it was very slushy out today and snowy srry for the book any help will be greatly appreciated
Old Feb 22, 2010 | 08:39 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
visually look at the starter and see if anything is shorting the two big posts on the starter. if not then see if you have 12 volts a the small wire going to the solenoid with the KOEO (position to make the fuel pump and other stuff work). if yes then that small wire is shorted to a Live power feed. If no then replace the starter because the internals of the solenoid are shorting and causing the motor to start unexpectedly
Old Feb 22, 2010 | 09:43 PM
LowLife's Avatar
LowLife is on a distinguished road
Old Feb 22, 2010 | 10:39 PM
argon929's Avatar
thanks its goin to the shop tomarrow i aint dealing with all that slush **** under there
scott_wheels
Engine & Internal
Jun 25, 2010 07:38 AM
94BlazerKid
May 28, 2009 05:01 PM
Krayziess
Tires and Wheels
Jan 14, 2009 09:18 AM
thecoutures
Apr 8, 2007 05:17 AM
ken erestu
Oct 31, 2006 09:30 PM
