Anyone here have a 95 or 94 CPI Vortec Intake Manifold laying around?
Hi all,
Does anyone here have a 1994 or 1995 CPI Vortec "W" vin Lower Intake Manifold laying around? or currently off there engine? i need to know if there are rear coolant passages on either side near the back of the intake by the distributor hole? or if there is nothing there but solid aluminum? thanks |
last time i pulled mine it had no coolant passages near the dist mounting.
why would you ask ??? if your in need of a good used one i can point you towards a few ranging from 25.00 to 450.00 let me know |
Originally Posted by cc4usa
(Post 263672)
why would you ask ??? if your in need of a good used one i can point you towards a few ranging from 25.00 to 450.00 let me know thanks |
gasket issues
i used the ms95832 my engine is a 95 w motor its in my s-10 lt blazer 4dr 4x4. its the red blazer in my garage
Didn't we already go through this...? You still haven't made the decision...??
Go with what is suggested for your truck. The ones that are blocked off could lead to corrosion of the intake manifold at that location if there is any seepage which would just sit there stagnant. In the end, it's your truck. If you think you'll get some more peace of mind with the gaksets meant for a different engine, then by all means, go for it. |
yes we talked about the 2 different gaskets but i did not pull my enigine apart yet to look in it because the weather has been bad everytime i attempt to do it. and now im getting close to the return date so i have to return a set so i dont get stuck with 2 sets. thats why im asking for someone who has an intake off there truck for now.
i'll ask my younger brother. he's currently putting a chromed CPI on his '83 Dime (to replace the factory plain aluminum one). he's coming up to my place this afternoon, so i'll get back to you shortly.
(Post 263906)
Originally Posted by bigdaddykane93
(Post 263931)
ok thanks so much. can you look at both sides of the intake for any rear coolant ports? just curious, what is an 83 Dime?
as for the "Dime" it's know as the S10 p/u. here's a pic of my brother's that i mentioned (the black one on the right) and a "satretched" '85 that me & my brother were building for a friend. http://i996.photobucket.com/albums/a...sstretch01.jpg |
ok thanks, that tells me i can use the blocked off intake gaskets ...
