Anyone know the function of a spider injector??
Old Mar 29, 2010 | 05:10 PM
truckstuff216's Avatar
truckstuff216 is on a distinguished road
Default Anyone know the function of a spider injector??
Recently, I had to do a fuel pump job on my 98 Blazer 4x4. That job is done but I suspected there to be another reason for it not starting. When I tested the spark on the plugs it wasn't getting a spark I replaced all the plugs, checked the new wires, changed the coil ignition, replaced the distibutor rotor, battery tested good, alternator is fine and the starter is new, Someone mentioned the spider injector could be bad... does anyone know the function of it and if it could be the reason why I'm not gettin a spark.
Any leads would be appreciated thanks,
truckstuff216
Old Mar 29, 2010 | 05:16 PM
rriddle3's Avatar
The injector delivers the fuel to the cylinders. It shouldn't have anything to do with spark.
Old Mar 29, 2010 | 05:19 PM
paulggoo's Avatar
paulggoo is on a distinguished road
It is not to injectors it could be Ignition control module bad fuse loose connection (look under no spark.)
Old Mar 29, 2010 | 09:44 PM
Brandon43's Avatar
Brandon43 is on a distinguished road
Just in case you were wondering what the spider injectors look like, here is a pic from my truck when i cleaned my upper intake manifold and injectors.
Attached Thumbnails Anyone know the function of a spider injector??-0321000004b.jpg
Old Mar 30, 2010 | 08:07 PM
Thanks for the tips Im pretty sure its not my spider injector. Im just looking to bring the spark back. ill try the crank sensor first.
where would the ignition control module? is it the mini electrical component attatched to the coil? and is there a forum specifically for ''no spark'' on this site?
Thanks,
truckstuff216
Last edited by swartlkk; Mar 30, 2010 at 08:19 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
bassson
Dec 3, 2013 11:51 PM
newguy
Mar 22, 2013 09:36 AM
bigdaddykane93
43
Jan 21, 2010 12:12 PM
JeffUSMC
Jan 16, 2010 12:53 PM
Partime Gearhead
Mar 5, 2007 09:34 PM
