Assistance with 2001 Blazer Heating issues
I have a 2001 Chevy Blazer that use to only blow heat or AC on #4 only. But recently it stopped all together. Now the only air I receive is forced air while I'm driving. Now I've replaced the resister, the blower motor (which wasn't fun by the way lol) as well as the fuses & the fuses behind the switches. I'm still not getting anything. Can someone give me any ideas on what else is wrong. I live in Michigan and have 3 children one of them is only 18 months old and winter is slowly approaching. HELP PLEASE!!!
Last edited by kmurphy143; Oct 28, 2013 at 11:13 AM. Reason: New title (repeating myself)
Just to double check you replaced the relay (mounted to the firewall right above the blower motor) AND the resistor (have to cut it out to the right of the blower motor)? Because my friend had a similar issue with his blazer (only high fan) and we changed his resistor and it was perfect on all settings again.
And have you checked to see if your getting power to the blower motor and/or resistor?
Fisherdave, I would start by checking your HVAC fuses. If are all good, test the power to the blower motor, if there's no power going to it on any setting then there is possibly a brake in a wire, if there is power going to it but it's not blowing then the blower motor is probly shot and needs to be replaced.
TAS
Apr 12, 2012 10:10 AM
Chris1115
Jun 20, 2011 12:08 AM
zx2guy
Oct 13, 2010 12:01 AM
2blzers
Dec 16, 2007 10:14 AM
