-   -   Automatic headlights (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/automatic-headlights-68797/)
Snowmonsterdude Mar 8, 2012 09:06 PM
I'm sure there's probably threads on this already but help me out here..is there a way to disable the automatic headlights so I can manually use the headlight switch? can anyone help me? or point me to a good thread about how to do this? thank you :)
AJBert Mar 8, 2012 10:21 PM
Very easy. Install a resistor, readily available from Radio Shack for a few pennies in place of the sensor. I still have four of them as I had to buy a five pack.
The amount of ohms you need depends on the year of your Blazer.
A simple search on here should find you what you need. I've already had a few beers tonight and, sorry to say, I am too lazy to do the search for you.
vic98blazer Mar 9, 2012 06:34 AM
or you could try to push the dome light override switch 3 or 4 times fast you will hear a ding ding and the lights should be off, but you have to do that every time you start the car
oldsbravada2000 Mar 9, 2012 08:56 AM
The dome light over-ride switch, just press it in and out 2 times and the lights will turn off.
bricooper78 Mar 18, 2012 09:31 PM
does this do anything with the drl lights? i'm not near the truck, plus it's dark, and i'll forget by morning lol sorry for asking :D
AJBert Mar 18, 2012 10:16 PM
The push button trick kills both the AHL and the DRL. The resistor only kills the AHL.
bricooper78 Mar 19, 2012 11:41 PM
i tried that button thing for a few minutes when i was leaving for work, then at work to lunch, and then tonight. no dice. the way i've been today, i can believe i did it wrong lol but it didn't work on my 98 jimmy slt
RetroBlazer Mar 20, 2012 12:13 AM
I want to ADD AHLs and DRLs to my '91....hahahhah
I'm no help.
newguy Mar 20, 2012 07:42 AM
Make sure your Ebrake is all the way up
step66 Mar 20, 2012 05:57 PM
Huh? I get the resistor suggestion,but I have stated here before JUST WHY would one want to dis-able the DRL's,a PROVEN safety factor! Unless you are doing something illeagal. Just my thought!
