Automatic Transfer Case Question
Old Nov 26, 2008 | 01:53 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: Automatic Transfer Case Question
Is the hose providing vacuum to that firewall celoniod connected at the bottommost nipple? JP[>:]
Old Nov 26, 2008 | 06:02 PM
I really am not trying to beat a dead horse here, but the funny thing about their claims is that they still do not list that it is comparable with Autotrak 2 fluid. Nothing in their literature at all. The only time I have ever seen this brand has been in motor oil at the corner gas station. No where else. I am all for a miracle fluid, but... I am very skeptical. Considering that a slip-stick situation like this can occur from using the wrong fluid in the transfer case, $16 ($32 if you flush it through after 100-500 miles) for the proper Autotrak 2 fluid might just be worth it.
Old Dec 2, 2008 | 04:22 PM
kmartin's Avatar
kmartin is an unknown quantity at this point
I will give my final on this, swartlkk. If you feel uncomfortable using something other then Autotrak 2, that is your choice. Better safe then sorry is what they say. Wolf Head tech support told me GM has not released the license on Autotrak 2, as you mentioned earlier. But they don't release the license because they have a deal with other companies for there chemicals. ($$$) And due to trademark laws they cannot list Autotrak 2. But if you notice on the list they do list General Motors, which can broadly include Autotrak 2. Since Wolf Head spent money and time on testing the Wolf Head Super Universal Sythetic ATF in Autotrak 2 application and my garage did the research to find it out, and I told then before they serviced my Blazer, I going to let the fluid in there. Its over 2,000 miles and I had no problem with it. My garage will be the first to hear about a problem. I can say if anything pops up. However, I will not actively promote this product, because as far as cost goes, $16 to replace your fliud in your transfer case is not that big of a deal.
Old Dec 2, 2008 | 06:18 PM
I guess you are not interested in changing the fluid to possibly cure the problem you are experiencing. There is a TSB on this issue specifically stating the slip-stick condition while turning. That is the only reason I have kept up with the mantra of using Autotrak 2 fluid. If it were not for that TSB, I would have stopped beating it to death already.
It is also possible that the damage was done prior to the use of the aftermarket fluid and there is nothing short of rebuilding/replacing the transfer case. Who knows, but all diagnosis starts with the simple things first.
Good luck.
Old Dec 3, 2008 | 12:48 PM
kmartin's Avatar
Oh, now I see where you are coming from(concerning a TSB) Obviously, you still believe there is a problem. Then this has been a problem since I had it. So back to the an earlier question: Has the dealer service center lied to me? What does it me when it is in Auto mode and the front axle is engaged? If I got to redo my transfer case, forget it.
Peru Motors: Is the hose providing vacuum to that firewall celoniod connected at the bottommost nipple? I don't know what you are trying to say, tell me where to specifically tell where to look.
Flyfishen
Jun 18, 2019 11:22 AM
kmartin
Jan 18, 2014 07:49 PM
bensaintonge
Dec 3, 2013 08:14 AM
scphill34
Mar 26, 2013 07:09 PM
Marcin
Oct 14, 2006 06:09 PM
