AWD rumbling after 5 min.
Old Nov 22, 2008 | 06:21 PM
dax44's Avatar
dax44 is an unknown quantity at this point
Default AWD rumbling after 5 min.
When I switch to AWD everything works fine for a few minutes, then I can start to feel a rumble getting gradually worse until I have to switch back to 2 WD after 5 min. I figure it's probably in need of a tranny fluid change but just want to make sure.
Suggestions? Anyone else had this??
Thanks
Old Nov 22, 2008 | 07:27 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: AWD rumbling after 5 min.
If you can switch to 2wd drive than it must be A4wd not AWD but similar. It may be that there is an issue in the A4wd system that is partly engaging the front axle. If it goes away when you switch drive modes it wouldnt be affected by the transmission.
Old Nov 23, 2008 | 10:06 PM
dax44's Avatar
I was meaning A4wd, didn't realize it was called that. So, any ideas on what it could be in the front axel that would cause it tostart rumbling after 5 min. of straight driving?? Anyone??
Thanks,
Old Nov 23, 2008 | 10:23 PM
portcqb's Avatar
I dont think it is the front axle it is most likely the transfer case partly engaging. Does the light on the controls blink when in A4wd or anything that it doesnt do it 2wd. Someone with more expirence with the issues with the controls of the switchable transfercase should be able to walk you through diagnostic steps. My AWD system doesnt have the ability to go into 2wd mode so I dont have all the vacum controls.
Old Nov 23, 2008 | 10:32 PM
dax44's Avatar
Thanks for the post. The light for A4wd comes on properly and I am sure that the transfer case is engaged properly. I've tested it a few times with the recent snow we've had. Big difference in traction from a stop.
That's the thing that concerns me, if it works fine for a few minutes at highway speed, then starts to rumble, then stops immediately when you switch back to 2WD, just wonder how/why. I often will switch to AWD on the highway when it's snow covered and slippery, the switch it off when you get to a clear area. I've always found it switches very smoothly.
Old Nov 24, 2008 | 04:47 PM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
Have you checked the diff fluid?
TigaHotty85
Jun 17, 2013 03:10 PM
Escohomie
Apr 7, 2012 04:48 PM
n7nms
Jul 22, 2011 10:40 AM
BresBlazy
Mar 7, 2011 01:06 AM
la~man
Engine & Internal
May 16, 2006 10:40 PM
