azer codes po101 & p0440
Old Aug 25, 2010 | 03:28 PM
wayneaaron's Avatar
wayneaaron is on a distinguished road
Default azer codes po101 & p0440
I am getting codes p0101 & l0440 and I need to know how to fix them
Old Aug 25, 2010 | 05:04 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
1. you should list year make model, 2 wheel drive or 4 wheel drive and engine size
2. the search featue on this forum works wonders
3. welcome to the forum
4. try these links
https://blazerforum.com/forum/showth...ghlight=po101\
https://blazerforum.com/forum/showth...ighlight=p0440
Old Aug 29, 2010 | 11:08 AM
davedidit's Avatar
davedidit is on a distinguished road
P0101 The Mass Airflow Sensor (MAF) measures the amount of air entering the engine and the Engine Control Module (ECM) uses the information to determine the proper amount of fuel quantity and ignition timing. The P0101 trouble code is set when the ECM detects a problem in the electrical circuit to the MAF Sensor.
P0440
This indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
I had a P0440 code almost drove me crazy for over a year
changed the fuel filter and it went away
Old Aug 29, 2010 | 01:14 PM
rriddle3's Avatar
More to the point:
P0101 Explained
P0440 Explained
Old Aug 30, 2010 | 10:12 PM
davedidit's Avatar
Thanks riddle
hey stop and have A Whataburger for me
I went ho High School at South West in Ft. Worth
and did some serious 4 wheelin in Johnson Co.
nharner
Nov 20, 2011 10:10 PM
xtremefirefighter
22
Nov 11, 2009 06:26 AM
Sneeeps
Oct 29, 2008 11:34 AM
rockon_79_54
Aug 19, 2008 05:27 PM
Bigblock396
Jul 18, 2007 09:49 PM
