Bad ideling
Old May 30, 2019 | 08:17 PM
Skullkrusher's Avatar
Skullkrusher is on a distinguished road
Sputtering when I give it gas while parked
Hi,I have 99 Chevy Blazer 4.3 with 217k I just had the intake gaskets put on and timing corrected on it my issue is the blazer is parked for now but when I turn it on it stays at idle but when I give it gas it sputters alot like it's got a fart stuck I just replaced iac and got a throttle position sensor at junkyard for now it turns on fine but that's it new o2 sensors put on last summer new spark plugs as well as distributor cap too i never had this issue ever can someone please let me know f anyone has had this problem I can take it to AutoZone to get scanned cause I don't want it to shut down on way there.
Old May 31, 2019 | 05:17 PM
Mike.308's Avatar
To make things clear:
- it was idling OK prior the intake gasket change?
- how did You set the distributor timing?
Old May 31, 2019 | 05:48 PM
cleburne red's Avatar
Yeah, I'm with Mike.
Sounds like something got messed up wirh the distributor.
You say you had the intake gaskets done. Did you do it, or take it to a shop?
Old May 31, 2019 | 06:02 PM
I had a mechanic come and do it for 250$ he set it on time first time and it was perfect,then when it started sputtering being parked for like 8,9 yrs..he came back and messed with timing 2time and then he finally came back and set it rite where it started rite away.could it be starving for gas cause I'm at an incline with back to street.it has a new map sensor.couls it be maybe throttle sensor?
Old May 31, 2019 | 06:19 PM
odat's Avatar
Parked for 8 or 9 years ? If so start out with draining old fuel and replace the fuel filter
Old Jun 1, 2019 | 09:36 AM
Yeah, 8-9 years is a rediculously long time to let a vehicle sit
Old Jun 1, 2019 | 10:17 AM
Mike.308's Avatar
Well I took it as a typo
If it isn't, then I'd suggest looking at the running engine's parameters to find out what is happening, for an accurate diagnosis. Do You have any codes thrown?
bblack13
Headers, Intake, & Exhaust
Jan 20, 2017 03:47 PM
drew_fur
Jun 8, 2011 03:52 AM
airmananderson420
Sep 5, 2010 07:34 PM
zr2kore
Jul 31, 2010 03:21 PM
jay_99z
May 30, 2010 04:45 PM
