Battery charged but not starting
Old Jul 14, 2010 | 10:54 AM
black4x4blazer's Avatar
black4x4blazer is on a distinguished road
Angry Battery charged but not starting
Hello Humble and mechanically inclined people.... need some help or advise pleeeasee...
97 balzer 4x4 s/10 body style, my battery ran down the day before because I did not close the rear hatch completely. I charged the battery overnight and the next morning she ran great. In the middle of the day when I was leaving the house I open the driver side door and there was a beeping sound, my flashers were going on and off and the starter just would not turn over. I had it towed to my house less thatn five miles away and never went over 20 miles and hour to overheat the tranny. I removed the started and had it checked at autozone and its fine. I still cannot get anything when I hit the ignition..... any nadvise or suggestions please. Thanks!
Old Jul 14, 2010 | 09:35 PM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
You killed the battery, get a new one, or make sure the battery cables are tight and corrosion free.
Old Jul 14, 2010 | 09:37 PM
Get in the car turn on the key, your voltage gauge should indicate 13 volts or so, if it does not the battery is bad, turn on the headlights the voltage should not drop and the lights should be bright, replace the battery, if the headlights work, then start the car, the voltage should stay high, if not replace the battery.
Old Jul 15, 2010 | 02:06 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Have the battery load tested @ the local auto parts store.
TigaHotty85
Jun 17, 2013 03:10 PM
pmezo
Jul 17, 2012 01:29 AM
stschuyler25
Nov 21, 2010 09:34 AM
Auce
Nov 27, 2008 11:47 PM
smahala1286
Nitrous, Super Chargers, & Turbos
Jun 27, 2005 10:47 PM
