Below 3/4 of a tank...
Old Dec 19, 2010 | 11:20 PM
thesubwaypusher's Avatar
thesubwaypusher is on a distinguished road
Default Below 3/4 of a tank...
Hi guys:
This is my first post and a hearty hello to everyone!
I have a 2002 Blazer that otherwise runs great. My problem is that when the tank is full and I crank the engine, it starts right up. However, when it gets lower than about 3/4, I can crank it and it won't start until I stop cranking and crank it again then it will start right up. I have had this problem for about 3 years now. I have just gotten used to cranking it once for three seconds, letting it go, and then cranking again until it starts about a second later. May I have thoughts on this problem?
Thanks for any assistance!
Chris
Old Dec 20, 2010 | 01:47 AM
bigkhans's Avatar
bigkhans is on a distinguished road
My first question is how accurate is your fuel gauge? Your sending unit is in the tank, and sometimes they get some build up that keeps them from moving and that would make your fuel gauge misread, however I don't think that would be the problem. I would still check though.
I'm not too sure about why your truck starts right up on full, but not at 3/4. I would try replacing the fuel filter and run some seafoam or some techron in the fuel and see if it improves anything.
Old Dec 20, 2010 | 07:32 AM
*Moving to 2nd Gen Tech* - The new member area is for new member introductions. Technical questions are more appropriate in the tech sections.
Have you tested the fuel pressure to make sure that it is coming up to the proper pressure (>55psi) and that it doesn't leak down more than a few psi after the pump shuts off?
BlaziNator
54
May 25, 2010 05:15 PM
ComputerNerdBD
14
Mar 23, 2010 05:28 PM
Meatwad
Nov 11, 2008 08:00 PM
watsonracingteam
Aug 25, 2008 04:03 PM
Navy85
Feb 24, 2008 08:12 PM
