Blaze goes in 4Lo - not 4Hi
Old Jan 24, 2008 | 03:32 PM
Matty Kling's Avatar
Matty Kling is an unknown quantity at this point
Default Blaze goes in 4Lo - not 4Hi
My Blazer shifts from 2wd to 4lo no problem, but I can't get it into4 hi..
WTF?!?
Old Jan 24, 2008 | 11:25 PM
Chevy Lover's Avatar
Default RE: Blaze goes in 4Lo - not 4Hi
The more info you give, the easier it is to answer.
I'm guessing that you have a 2000 blazer with a 2 speed selectable transfer case NVG233.
It sounds like you either have a bad electrical connection to the encoder motor or a failed encoder motor.
Old Jan 25, 2008 | 07:00 AM
Jman's Avatar
Jman is an unknown quantity at this point
Same thing happened to my wifes 95 blazer. 4 hi no work, 4lo was good. I switched the switch in the dash and its all better. nice easy fix for me anyway.
Old Jan 25, 2008 | 07:52 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
Do you have the 4button autotrac 4x4 switch?
Old Jan 25, 2008 | 11:07 AM
I do have a 2000 LS...
I have 3 buttons on my dash (2wd, 4hi and 4lo)... When I push the 4hi (when its in 2wd) BOTHthe 4hi and 4 lo blink... then switches to 2wd... When I push the 4lo button both 4hi and 4lo blink again, but it switched to 4 lo. And i feel the lower gears - so I know i'm in 4lo...
WEIRD!
Old Jan 28, 2008 | 12:39 PM
firemansc32's Avatar
firemansc32 is an unknown quantity at this point
Had a similar issue. Only I have the Four button Auto 4hi. On mine the low range would ingage in the T-case but not the front diff., so 4hi wouldn't work at all. Turned out to be that the cable from the vacuum actuator to the front diff. had frozen up. A little over $50 later and a new cable it worked just fine. The actuator is located under the battery on the inside fender. How to from sevrice manual below.
[align=left] [/align]
[IMG]local://upfiles/9478/AB9ACCF85C9E4A1580C0AE9F8CB5675E.jpg[/IMG]
kendog
Feb 13, 2021 11:41 AM
jeffrozar
Nov 4, 2011 03:49 PM
jeffrozar
Nov 4, 2011 10:08 AM
magicpotatoes
Jun 24, 2009 04:29 PM
