-   -   Blazer cranks but won't start (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/blazer-cranks-but-wont-start-37420/)
Rhodes19 Nov 28, 2009 08:22 AM
Hi All,
My daughter's '99 Blazer will crank and turn over but won't start. She ran the battery down trying to start it so I recharged it. When I went to start it all lights and gages worked. It turned over a little so I jumped the battery to my truck, gave it a few minutes and tried to start it. The motor/starter are turning over but still won't start. It sounds like it will catch/start at times but then doesn't. There is fuel in the tank. Any ideas or suggestions? I did some reading on the sight and am wondering if it might be the fuel pump (which was changed out a couple of years ago). What can I check next and how would I do that? Thanks for any and all help.
*Combining Consecutive Posts*
Ok, maybe not the pump but I'm not sure. When I turn the key all they way before the starter kicks in, I hear a low hum for about 2 seconds. After trying to start it and when I turn the key to the off position, I hear a 2 second hum again. Not sure where it is comeing from thought. I read somewhere the fuel pump will turn on for 2 seconds before starting and then again for 2 seconds after the ignition is turned off. Hopefully the problem is not the pump but something easier I can fix. Again, thanks for any and all help.
Oh, sorry, one more bit of info. My daughter tells me that her Blazer will also chock, become jerky, or slow down when she tries to accelerate on the highway. Thanks.
Rhodes19 Nov 29, 2009 09:14 AM
Bump :icon_bump1:
jigger Nov 29, 2009 11:07 AM
Isn't that the way it goes-Oh by the way dad the left rear wheel fell off too! :icon_doh:
Do a fuel pressure test, low fuel pressure could make it run like you discribed. Could be fuel filter or fuel pressure regulator.
1) autozone has test equip. to check fuel pressure (no cost)
2) fuel filter (inexpensive fix)
Now you can start throwing parts at it! :icon_bricks:
Rhodes19 Nov 29, 2009 01:11 PM
Actually, now that you mention it, I had a soldier tell me (when I was in the army) that one of my vehicles lost it's back right tire. The mechanics did a tire rotation and forgot to put the lug nuts back on and drove it out of the motor pool loaded with ammo. The tire fell out right in front of the Brigade HQ!
Jigger, thanks for your help and information, I really appreciate it. I could not pull the spark plug wires to look for spark because they were on real tight and I couldn't get a good grip on them. I did check for current at the distibuter and got current so I am thinking fuel. I can change the fuel filter but I'll have to do some research on the pressure gage and connections. Once I know what to look for I can usually do the work. Next stop, Auto Zone. Thanks. :D Throwing parts at it. Boy, thats no lie. :)
jigger Nov 29, 2009 02:26 PM
For the fuel pressure there is a test port between the fire wall and the plenum, looks like a tire valve thingie. It sticks straight up, it's called a schrader valve. Take off the black cap and put a rag under it then push the little pin and it should squirt a little gas even with the engine off, JUST BE CAREFUL! If it dosen't squirt at all then you got no fuel pressure at all. There sould be some static pressure with out the thing running. Next step the fuel filter, it's next to the frame around the driver's door. When you take it loose it WILL drip fuel have a pan and some rags handy!
The autozone test kit has directions- just follow them and see what you got! You hook it up to the above mentioned schrader valve, it's really easy.
THAT'S IT GOOD LUCK
swartlkk Nov 29, 2009 02:39 PM
Start here:
96+ Fuel System Diagnosis
Give us the SPECIFIC fuel pressure reading as well as the pressure drop after the pump shuts off. Just putting a screw driver to the schrader valve won't tell you much. Sure it'll tell you if there is pressure, but unless you can tell the difference between 50psi and 60psi...
The fuel pressure test port is located right on top of the engine on the main fuel feed line (different location than on the CPI engines).
jigger Nov 29, 2009 04:07 PM
DANG! GOT ME AGAIN! Once again I yield to the smart guys!!!:icon_hug:
Rhodes19 Nov 30, 2009 06:11 PM
THAT'S IT GOOD LUCK
Thanks Jigger. I actually know what you are talking about! I was looking at it yesterday and thougth "that was a strange place to pump air in". :D I'll see about getting off early tomorrow and stop by Auto Zone for the kit. I'll let you know how it goes. Thanks again for your help. I really appreciate it.
Originally Posted by swartlkk (Post 269040)
Start here:
Thanks swartlkk. Looks like I have some homework tonight. :) I'll do the test tomorrow night and I'll post the results. Thanks again for your help. I appreciate what you and jigger are doing for me.
Rhodes19 Dec 2, 2009 09:33 AM
Well, bummer. I stopped at AutoZone (2 of them) and an Advanced Auto Parts and none of them had a fuel pressure test kits to borrow or rent. Could buy them for $42 if they where in stock. I'll look around and see if I can find one to use. If all else fails, I'll have to buy one.
I did however, check the fuel test port and some gas did come out. Not much though. I tried to crank the car again, rechecked and got some more fuel to come out. Again, not much. As soon as I can get a test kit I'll post the results. Thanks.
jigger Dec 2, 2009 08:39 PM
If you have Kragen/ O'Riley they have them too.
