-   -   Blazer cranks but won't start (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/blazer-cranks-but-wont-start-37420/)
jigger May 18, 2010 12:35 AM
Rhodes tell your daughter if you want the pump to last don't run it with less than a quarter tank of gas. The pump uses the fuel to keep the pump motor cool.
I'm sorry-stupid me, tell a woman not to go below a quarter tank. YEA RIGHT!!!!
Rhodes19 May 18, 2010 10:21 AM
LOL!!!!! That's funny!! Thanks jigger, that is good info by the way. I never thought of gas keeping the pump cool and extending the life of the pump. Makes sense. I know one of the things she had problems with was the fuel gage getting stuck or bounced around when the tank was half full or less. I think the new pump will fix that too.
KRUSHER May 18, 2010 11:15 AM
Jigger I resemble that remark and I'm not a woman! :icon_doh: Just joking but mine has gone below 1/4 tank (I don't like stopping) but I try to keep it above 1/4.
Rhodes19 mine does the same thing. I can have almost 1/2 tank and turn a corner, back or pull up on a hill and it will drop to E and the light comes on. sometimes whill driving it will eventually go back up. There has been a couple of times that I forget where it really is and have ran out of gas once! not good.
jigger May 19, 2010 12:30 AM
Maybe it got worn out bouncing on the bottom of the tank! ha ha!
It won't immediatly catch fire or anything like that if you run below a quarter--it just helps prolong things if you don't.
Rhodes19 May 19, 2010 06:46 AM
Hi KRUSHER,
Yeah, she was having the same problem and the mechanic told us it could be the sending unit. Ok, easy fix. :icon_no: Turns out the sending unit is in/on the pump and they would have to drop the tank to fix it!!! The temporary solution, top off regularly. Of course I had to go bring her gas several times. LOL Oh well. I'll have to sneak it out for a drive every so often so I can catch problems before they occur before they become worse.
Rhodes19 May 19, 2010 06:51 AM
It probably did!!! She's run it dry a couple of times. I guess pumps are pumps. I have several salt water/reef aquariums and you don't want to run the pump dry. They won't beak or seize but you do wear them down prematurely. When she comes home next weekend and I give her keys back to her, one of the things I'll tell her is not to let it drop below a 1/4 tank.
RyanReed Feb 15, 2013 08:03 PM
I'm Having the same problem with my 99 s10 blazer. Put a new crank and cam sensor as well as a coil. started for a few days, then back to the same problem. hooked up fuel pressure gauge and it is at 68 psi with the key in the on position it will bleed down to 0 rather fast.. Any suggestions?
KRUSHER Feb 15, 2013 08:50 PM
bad pressure regulator?
RyanReed Feb 15, 2013 09:46 PM
Thats my next step in the morning. Also am having an intermittent spark issue. Which lead to the replacement of the cam and crank sensor along with the coil. I'll keep ya posted, i'm sure ill be back on here if its not the FPR
