blazer dying while driving
my blazer started dying recently while i was driving it... so i would have to come to a stop in traffic and start the damn thing again... i replaced the ECM(Electronic control Module) and was told that should fix it but it didnt... I have a 1999 Blazer LT with 4x4 and 4.3 Vortec...
Any help appreciated guys, thanks. |
Would it always start back up after it would stall?
yes it always starts back up.......
I had a similar problem, stalling while decellerating or stopping at a traffic light. EGR valve was working properly and was not problem. during lengthy drives, typically over 20 miles at 55 MPH, my fuel pump would start "whining". Figuring a partially clogged fuel filter would force the fuel pump to work harder, I replaced it. It was opened up and found to be clean with no debris in it. My next step will be to replace the fuel pump/fuel gauge sending unit assembly. The "whining" sound comes and goes. When on an extended drive, the sound it makes is like that of a tractor trailer passing you on the interstate.....a steady mid to high pitched whine. On short drives around town there is no whining and if it is whining and I shut engine off for a bit, the sound goes away.
i do here the fuel pump,but it really not a whining sound,just sounds like its working,sounds normal,but its been about a yr or so sence ive replaced the fuel filter,think i should go ahead and replace the filter,and see what happens,and my other problem is that the heater even feels like its on always blowing heat into the blazer always,even being off
This may sound strange, But! Maybe Kyle can chime in on this, Does it only stall when your coming to a stop?? I`m thinking it may be the lock up on the torque converter , stalling the truck.. How does it shift? smooth or it bangs into gears?
it stalls in mid-flight,like going 40 or 50 miles per hr,only after driving an hr or so,then keeps on doing it
also it does shifts into gear just fine |
Does it do it more frequently once it starts? If so, it sounds like you might be loosing spark. This could either result from an overheating ICM or coil. The coil would likely cause misfire issues, but an overheating ICM can just shut off the engine.
This seems a bit odd.. I am having a similar problem with my rig, difference is my truck hates me at all speeds. Once I get over 20 or so you can feel the truck surge like it is trying to die, but the transmission is still moving and give it the manual transmission effect. You have to come to a complete stop to start it back up?
where is the icm location
the icm is the control modle right.if so ive replaced that,so is the next step is to replace the coil.........??????,plus thxs for all the feed-back guys,
