Blazer Electrical Issues
I've got a 97' Blazer 4x4 with some electrical issues. A bunch of things all of a sudden decided not to work today:
-4wd indicator lights aren't lit up -when I push the 4wd hi or lo button, nothing happens (there's usually a click noise)(I'm stuck in 2wd) -gauge cluster won't light up when I put the headlights on but the the warning indicator symbols do still work -all of the others buttons on the dash don't light up -chime doesn't sound if I leave my lights on when I turn the car off -rear running lights don't go on but the brake lights work -parking lights in frontwon't go on but they blink for the turn signal -rear wiperdoesn't work All of these things worked last night but didn't today. I checked some of the fuses and also had the alternator checked but they were alright. I greatly appreciate the help if anyone knows whats going on. Thanks Viperguy |
RE: Blazer Electrical Issues
Two things come to mind.
Headlight switch has crapped out, if I understand your post correctly, the light siwtch controls just about evrything you mentioned that isn't working. Brakes, blinkers are on a seperate circuit form the parking, convienence lights, and they do not go through the light swtich. The other is battery connections. |
Now, what about the 4x4 controls, though. Those lights are supposed to stay on even when the headlights aren't switched on. Also, I'm a little confused abouta bad headlight switch not allowing me to switch it into 4wd. By the way, the headlights themselves do still go on. Thanks again for the help.
Viperguy |
It sounds like you have a number of things wrong, but I will have to look at the wiring diagrams to be sure... I think that Tim (hanr3) was just covering those that he had answers for.
On the 4wd issue, try pulling the switch and reseating the plug. We have seen a number of 4wd issues be caused by a loose connection at either the switch itself or the TCCM which is located behind the passenger side kick panel. |
