blazer keeps dieing when warm
Old Jul 30, 2013 | 01:55 AM
neal's Avatar
neal is on a distinguished road
Default blazer keeps dieing when warm
I have a 2002 s 10 blazer just turned 100,000 miles. it has been acting strange lately. the truck starts and runs fine till it gets warm, it has been getting hot mostly when the air is on (the hot weather here doesn't help) lately when it gets warm it just dies. let it set for a few min. starts then runs for about 2 min, then dies. start it runs then dies. someone told me it could be the cat. took it off the pre cat was trashed the insides were melted and broke up and most of it were in the cat. changed it with new exhaust every thing from exhaust manifolds back. after all that i start the truck let it warm up and guess what it still dies. I am hoping that someone out there has some ideas as to what the problem could be
Old Jul 30, 2013 | 06:34 AM
cubawashere's Avatar
cubawashere is on a distinguished road
I would first check for codes, regardless if the CEL light is on or not. Just in case of pending codes retrieved, they will help in diagnosing issue. Also, Go through some of the relays and their connectors, mainly looking for corrosion or weak contact points. If all is well there, next hook up fuel pressure gauge...1st while truck acts normal and then again when truck starts and stalls. Psi should read at least 55 while running at idle, when revving 2k RPM @58-62Psi. When it stalls see how fast fuel pressure falls in 10mns. then repeat 2-3 times.
The things I listed above will show lots of info and should make great headway in solving whatever problem you may be having. I strongly believe it is a fuel issue you are having from the symptoms. Good luck! Can't wait to hear an update!
Old Jul 30, 2013 | 06:59 AM
blazer down under's Avatar
blazer down under is on a distinguished road
sounds a little like the pick up in the dizzy.at work i have had a fare few Chev's with similar issue's although normally they run fine cold by the time there at running temp start missing and carrying on then die till the dizzy cools off a little. when it stops next take a spare spark plug plug it into a plug lead sit it on the engine block or a good earth and spin over the engine whilst looking at the plug see if spark is present
Old Jul 30, 2013 | 10:08 AM
spittybays
Guest
Posts: n/a
Go to the BF homepage and in the google box type in "ignition control module symptoms" or "ICM symptoms", see if you can relate anything to what is happening.
Old Jul 30, 2013 | 08:46 PM
neal's Avatar
sorry I didn't mention I before I checked the fuel system it is fine. changed the icm tonight. let it run for about an hour in the drive way. did not die. will drive it in the next few days and see if I still have a problem
Old May 5, 2014 | 04:49 AM
Kube's Avatar
Kube is on a distinguished road
Sorry to post to an old thread, but I'm wondering if changing the ICM fixed your problem. I'm having the same problem with mine. Once the engine gets hot it dies. I pop the hood, wait for a while, then it runs fine for a little while, then the throttle becomes unresponsive and it dies again. I've been stranded out in the woods a few times and now I'm leery about taking it out of town.
Old May 6, 2014 | 10:30 AM
neal's Avatar
I did change the pcm and it still died, finaly found my problem about two years ago I installed a msd street ignition it had gone bad. took it off and every thing is fine.
Old May 9, 2014 | 09:18 PM
The MSD SUCKS on chevys... I've always had to remove them from vehicles... darn young people expect to get automatic performance out of them....like cold air intakes. SMH Nothing but issues and CEL codes and they wind up throwing parts at it until they come to me....Then I rid the engine of all that poison MSD....
Badmonkey32
25
Dec 3, 2012 06:20 PM
ladeedawdeedaw
Dec 14, 2010 03:14 PM
millertimee1
Mar 22, 2010 12:50 PM
Zasder
Apr 1, 2008 07:56 PM
Inferno
Oct 22, 2006 08:56 PM
