Blazer LT 95 just dies, runs Ok and dies again
Old Oct 29, 2008 | 01:24 PM
Poligono's Avatar
Poligono is an unknown quantity at this point
Default Blazer LT 95 just dies, runs Ok and dies again
Hi there!
Iown aBlazer LT '95 4WD, startsand runs ok, but i'm dealing with a problemwhen thevehicle runsup to 30 miles or so. After that (specially in hot weather conditions) the truck just dies followed by the noise related to the fuel pump, when that happen i set thetransmission in parking position and turnthe vehicleon again, but after 3 minutes on the run theBlazer dies again.
I park the vehicle in the street and 4 Hours later the Blazerstarts and runs ok again,so i can take it home whitout any problems.
I don't know what to do or where to start, i don't know if the source of the problem could be electrical, or related to the fuel system, i already checked this post:
https://blazerforum.com/m_174722/tm.htm
It wasawesome tounderstand how the fuel system works,isearch in thesitelooking for a related problem but can't find anything.
Any help will be appreciated. Tks!
Polo.
Old Oct 30, 2008 | 01:26 PM
Poligono's Avatar
Default RE: Blazer LT 95 just dies, runs Ok and dies again
Any ideas?
Tks!
Old Oct 31, 2008 | 11:04 AM
chevyblazerlover2's Avatar
chevyblazerlover2 is an unknown quantity at this point
i had the same problem a couple months ago with my 96 blazer, try checking the temperature control sensor on top of the engine by the termostat
Old Oct 31, 2008 | 05:25 PM
Poligono's Avatar
ORIGINAL: chevyblazerlover2
Good! Now i know where to start...I'll check that sensor and post the result very soon.
Tks a lot
Old Oct 31, 2008 | 09:44 PM
skoot61's Avatar
skoot61 is an unknown quantity at this point
I had similar problems too.... https://blazerforum.com/m_166701/mpa.../tm.htm#169720
Old Nov 3, 2008 | 06:01 PM
Poligono's Avatar
ORIGINAL: skoot61
Wow! That seems to bea very expensive list...i'll start with the sensor and the thermostat...hope the problem can be solved soon.
Tks a lot for share all your experience [sm=smiley20.gif]
ernestiv
Apr 18, 2015 03:02 PM
fnbutch
Jun 25, 2013 12:08 AM
zakm0n
Jan 10, 2011 11:42 AM
KRUSHER
Jan 2, 2010 07:25 PM
adamsrg
Jan 18, 2007 08:22 PM
