Blazer rear brake problems.
Hi everyone, I finally settled on a 04 xtreme. On my way home from the dealer today. (Didnt even have it an hour) the rear brakes got hot to the point they where smoking alot. Seemed like passenger side was the worst. I called the sales guy but i bought it as is so im pretty sure im stuck with fixn it myself. I think maybe ebrake is some how stuck on or maybe calipers are sticking. The dealer said it had new pads (probably not to new now) a guy at tires plus told me these trucks have issue with calipers and you have to buy new ones when changing rear pads. ???
your going to have to take it apart to find the problem
places like Napa will sell you a rebuilt caliper with with all new hardware
I do suggest taking the pin hardware out of a rebuilt caliper and lubing it with a quality bake lube if you go that route
Just went through all the brake problems, take calipers apart and lube the sliders. My e-brake was also on a little all the time, everything was getting hot. I removed the e-brakes and through them in the trash. Blazer rolls better then ever now. No more e-brakes but who uses it anyway. Been fighting that e-brake for years, but not any more.
I just did the same thing on both rears. Ruined a new set of pads. I ended up replacing the E-Brake Shoes, calipers and pads. For the calipers I filled them up with brake fluid on the bench to eliminate as much air as possible. After installation I used my vacumn pump to bleed the calipers at the bleed fitting. Brakes are solid and not spongy at all.
Crack the bleed valve open. Connect vacumn pump hose to the bleed valve fitting. My vacumn pump kit came with small container that has a lid for connecting one hose to the pump and the other to the liquid side. Squeeze the pump handle to create a vacumn making sure that the hose stays on the bleed valve fitting it will suck the fluid into the container.
i had same problem with new brakes. put them on and the calipers didnt work right. for some reason when you press them back in they dont work right. i had this with both my blazers. 2001 and 2004. bought autozone calipers with liftime warranty. northern states really tear them up.
