Blazer stalling :(
Old Jul 14, 2013 | 08:53 PM
  #31
SFG is the broadcast number! Good job!
AC Delco #MU1772 is the pump module that you need.
Old Jul 18, 2013 | 06:48 PM
  #32
Victorblaze's Avatar
Victorblaze is on a distinguished road
so i replaced the fuel pump and the truck ran really good for like three days now it stalls in drive after a while of driving but if i put it in neutral the truck doesnt stall. when put in drive it jumps like if it was a stick with the clutch let go. i did get two codes p1870 and a p1509 which is the iac and slippage in trany hard shift 1-2 gear. im dreading a tranny rebuild..... hope its not the torque converter
Old Jul 19, 2013 | 01:28 AM
  #33
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Don't fear the P1870. That code popped up on my '98 Jimmy. I installed the TeckPak FitzAll replacement TCC valve and it took the problem away. Here's a link to the valve:
TCC VALVE from Teckpak / Fitzall
There are several write-ups about how to install the valve. I was able to install it myself pretty easily in one evening. I would also suggest installing a Trans-Go orange box shift kit while you have the valve body off the transmission. It will improve the shifts and extend the life of your transmission.
Old Aug 27, 2013 | 09:20 PM
  #34
so i got the blazer back and running it turned out that the fuel pump was fried thank you all for the help much appriceated. i also did a complete tranny rebuild because my torque converter was begining to lock up which was causing my truck to idle rough at a stop light and sometimes would stall the truck. thank you all once again
skoot61
Jul 21, 2008 07:29 PM
pkallis
Jun 23, 2008 11:07 AM
ralph10
Mar 23, 2007 01:21 PM
dragonsdeath
Oct 7, 2006 01:08 AM
Urenemy
Jul 7, 2006 02:40 PM
