Blazer staring problems! please help!
Ok, so first off. When the car is cold it will fire right up! But the next cranks it will not start up unless I floor the gas?? I cleaned the throttle body, I tried a new idle air sensor, and i've tried a new fuel filter, I have tried sea foaming it. Nothing seems to work and I dont wanna keep spending money on stuff that dosent need fixing... Also I have liquid and white smoke coming out my tailpipe when I fire it up and give it gas. not sure if thats part of the problem or not. Also several times i went offroad and water was sucked into my engine maybe that messed it up idk... Thanks for reading! Please Help!
~ Also!! sometimes it may start up warm but it will be idleing at 300rpm! very low until givin gas and it will go to the regular 1k idle,
~ And the first time i switch from park to any gear from that bad crank it will bog down! and sometimes cut off! thx!
Last edited by justinbrown1993; Oct 7, 2012 at 08:31 PM. Reason: trying to give more description of the problem.
IME (In My Experience) white smoke = antifreeze burning.
1000 rpm at idle is for a cold engine, not a warm, that should be 550rpm +-.
Really sounds like a manifold leak allowing antifreeze into the cylinders. I had that with a '95 Toyota 4x4... ran great 'till I started it after normal running temp for awhile & fogged the neighborhood for mosquitoes lol.
Could be the lower intake manifold gasket or a head gasket leaking.
Have you checked the plugs? What color are they?
The liquid from the exhaust is more than likely normal. You'll notice all cars dripping water from the tailpipe, in fact they have drain holes on the underside of the pipe usually.
ok pulled all the plugs, all of them are jet black, left #2 that is facing toward engine had a liquid on them but it didnt seem like anything couldnt smell it cuz they all smell like gas lol
drummerdude
16
Dec 8, 2012 07:09 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
GMdesigner
Jun 22, 2007 12:02 PM
