Blazer Won't Start
Old Jan 8, 2010 | 11:31 AM
erbeckham's Avatar
erbeckham is on a distinguished road
Default Blazer Won't Start
Ok, I have a 95 Blazer engine code W, It won't start in the cold, has new Delphi Fuel Pump, Fuel Filter and Pressure Regulator. New Ignition switch, has bright blue spark, 130+psi compression in all cylinders, plugs only have 3000 miles on them distributer and rotor are clean and dry. Tried removing cat thinking it was plugged still no start. Tried either, carb cleaner and still no start, any help would be great.
Old Jan 8, 2010 | 12:26 PM
Sounds like you have spark, but have you verified that it is timed properly?
Old Jan 8, 2010 | 12:55 PM
erbeckham's Avatar
Default timed correctly
Cannot adjust the timing via the distributer, what else could it be. I am possibly thinking the ignition control module. That is the only thing I can possibly think of. I just don't have the money to be throwing parts at it. It started everyday this week until yesterday now it won't start at all.
Old Jan 8, 2010 | 05:23 PM
Thanks for telling me something I already know... Not being able to adjust it and checking to ensure that something hasn't happened to change base timing are two ENTIRELY different things. Do not be so quick to dismiss it.
Check the timing. Test the ICM and coil. By all means, DO NOT buy anything until you have confirmed that it is the problem or at least a problem.
Old Jan 9, 2010 | 10:10 AM
erbeckham's Avatar
Default found fix
I took the ECM out from under the hood and brought it inside to warm up to room temperature. Threw it back in the car and she started right up, I threw it in the freezer then no start let warm up to room temp again starts right up so i believe I have found the problem probably a solder connection on the board. So I found a guy on ebay who lives about an hour away called Spareecm, he has a few in stock and will flash them with my VIN for 89.95. Thanks for all the help thanks.
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
