Blazer won't start
Hi all,
I went to start my truck today, and after inserting the key, the battery just died (or seemed to). All electrical was out. I assumed it was the battery, since all power went off. As I tried to boost it, just by conencting the posititve to positive, all electrical came back. (the alarm went off). After completing the boosting sequence, I went to start it again, and as soon as I crank, all the electrical shuts down. At one point, after an apparent "electrical shutdown", I opened one of the doors, and not realizing the alarm was set, it rang and the electrical came back. I checked the battery voltage, and showing 11.7 volts. I checked the fuses and all seem to be in working order. Any ideas? |
The only thing I can think of is maybe a bad connection on the positive battery post. Might want to clean that good and see if it helps.
I had a similar problem and it happened several times.
I finally fixed it by removing both battery posts, cleaning both the battery side and the strap side with a wire brush, and then remounting them and tightening them up quite a bit. It's worked for about a year now with no repeats of the problem. Hope this helps.. |
I agree with the above bad connection posts. Also check the large cable connection at the starter. I had a similar problem about 5 years ago. Cleaned the starter terminal, and it hasn't happened since.
