Blazer won't start
Old Mar 5, 2011 | 01:08 PM
97Blazer_LSQ's Avatar
97Blazer_LSQ is an unknown quantity at this point
Default Blazer won't start
Hi all,
I went to start my truck today, and after inserting the key, the battery just died (or seemed to). All electrical was out.
I assumed it was the battery, since all power went off.
As I tried to boost it, just by conencting the posititve to positive, all electrical came back. (the alarm went off).
After completing the boosting sequence, I went to start it again, and as soon as I crank, all the electrical shuts down.
At one point, after an apparent "electrical shutdown", I opened one of the doors, and not realizing the alarm was set, it rang and the electrical came back.
I checked the battery voltage, and showing 11.7 volts.
I checked the fuses and all seem to be in working order.
Any ideas?
Old Mar 5, 2011 | 07:41 PM
ffox's Avatar
ffox is on a distinguished road
The only thing I can think of is maybe a bad connection on the positive battery post. Might want to clean that good and see if it helps.
Old Mar 9, 2011 | 04:20 PM
steelrfn's Avatar
steelrfn is an unknown quantity at this point
I had a similar problem and it happened several times.
I finally fixed it by removing both battery posts, cleaning both the battery side and the strap side with a wire brush, and then remounting them and tightening them up quite a bit.
It's worked for about a year now with no repeats of the problem.
Hope this helps..
Old Mar 9, 2011 | 05:53 PM
TouringMike's Avatar
TouringMike is on a distinguished road
I agree with the above bad connection posts. Also check the large cable connection at the starter. I had a similar problem about 5 years ago. Cleaned the starter terminal, and it hasn't happened since.
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
