blazer wont start
Old Nov 28, 2018 | 07:21 AM
LesMyer's Avatar
Originally Posted by Spencer Grow
the valves should be closed right?valves closed at tdc. Distributor on the six.
Yes that is correct. Has the outer ring on your balancer slipped? Maybe checking with a piston stop is in order?
Old Nov 28, 2018 | 09:14 AM
Spencer Grow's Avatar
Spencer Grow is on a distinguished road
no one has given that suggestion yet I'll check that. I'll give an update soon.
Old Nov 30, 2018 | 03:26 PM
Thanks for info. Started up no problem gonna put a new balancer. Never had an issue like that.
Old Nov 30, 2018 | 07:08 PM
Ok so it's running and still throwing a p0300 could the balancer cause a multiple misfire code? Keep in mind I've replaced cap rotor and gear and crank and cam shaft sensor. Plugs and wires Also.
Old Dec 1, 2018 | 08:57 AM
LesMyer's Avatar
From factory manual: See 4th down. Does it actually feel like it is missing? Did you verify that the balancer ring has turned by using a piston stop? Also you should be aware that replacing the crank sensor requires the sensor relearn to be done or false misfire codes can appear from that as well.
I always say to test the misfire detection system by monitoring the misfire pids for all 6 cylinders and inducing a miss on specific cylinders, one at a time. You would be surprised how screwed up the misfire detection can get. If it works properly when you induce a miss then it is fine. If it doesn't, then all bets are off for misfire codes being legit and the SES light staying off.
burnsdomain
Aug 11, 2019 07:25 AM
robwatson
May 22, 2013 05:40 PM
finity
Mar 20, 2012 08:57 PM
ramrod83
Mar 14, 2011 12:04 AM
rkosu02
13
Feb 27, 2011 06:53 PM
