blazer wont start or has power
Old Dec 21, 2007 | 09:31 PM
blazer_95's Avatar
blazer_95 is an unknown quantity at this point
Default blazer wont start or has power
I put a new motor in my 95 blazer and reconected every thing and i have know power to the entire blazer, i even checked all the wiring again as well. Also how many fuse boxes and where are they in the 95's?
Old Dec 21, 2007 | 09:35 PM
hillbillyinOhio's Avatar
Default RE: blazer wont start or has power
moved to correct section.
Old Dec 22, 2007 | 11:51 AM
This is a very difficult one to help with... You have to go back through, check and double check EVERYTHING that was done. Start with the power issue. Working from the battery out, probe at the terminals on the starter and in the fuse box, etc for power. Use a test wire connected to the battery negative for the ground in your tests to eliminate a problem with the grounding system. If you find +12V power at all of the required points, then move on to inspecting the grounding from the battery to the engine, body, and frame.
Old Dec 22, 2007 | 05:05 PM
blazer_95's Avatar
ok thankyou. sorry bout the confusion this was my first time doing a post my self so i got confused
chevylover5
Dec 24, 2013 08:31 AM
1996chevyblazer
Jul 14, 2013 07:55 AM
Klturi421
Jun 29, 2012 10:20 AM
blazer_95
Dec 22, 2007 11:48 AM
fast400
Aug 31, 2007 05:07 PM
