blazer wont start when its raining outside?
Old Aug 22, 2008 | 10:04 AM
mexisexisuperman's Avatar
mexisexisuperman is an unknown quantity at this point
Default blazer wont start when its raining outside?
my blazer wont start when its raining outside but when its nice out it fires right up. or when im driving it and it rains it dies out eventually and wont fire up till its dry out. help!!!
Old Aug 22, 2008 | 10:09 AM
bjsx8f's Avatar
bjsx8f is an unknown quantity at this point
Default RE: blazer wont start when its raining outside?
does it throw any codes?
Old Aug 22, 2008 | 10:11 AM
What have you done to try to correct this problem? I would say that you have a spark leak in the distributor and or spark plug wires. The water helps conduct the spark to ground before it gets to the plug.
To verify, at night with the engine running, take a spray bottle with water in it and mist the spark plug wires and distributor. If you see sparks jumping out, then that is your problem. A new distributor cap and rotor as well as new plugs and wires should cure this problem.
Old Aug 22, 2008 | 10:16 AM
bjsx8f's Avatar
yeah thats what I was thinking... I had a similar problem but it threw a random miss fire code... On the cap and rotor make sure there is not contact except from the pin... On an replacement rotor from autozone there is a plastic piece on the top closest to the cap that was rubbing on mine which caused a random miss fire in time. Also on your cap make sure there is only one small mark on each metal pin from spark contact... If a lot of the pins have white on them then your sparks are jumping around quite a bit
Darla Smith Garrett
Jun 16, 2012 04:18 PM
proper
Jan 13, 2010 06:49 PM
kdavenport316
Jul 31, 2009 03:51 PM
copper_eyes
Jan 12, 2008 12:11 AM
RCars2
Aug 4, 2007 11:29 PM
