Blazer's 4wd Performance
Old Feb 18, 2018 | 09:58 AM
  #21
LannyL81's Avatar
Regarding my statement about replacing the rear diff....yeah I would just replace the carrier. My question about whether drum or disc brakes was for when I go looking so I do not have to spin every Chevy truck with an 7.625" diff to see if it has G80 or not.
Do not know anything about this "luchbox" locker...will have to investigate it....but probably just go with an aftermarket carrier.
Old Feb 18, 2018 | 01:55 PM
  #22
Rusty Nuts's Avatar
Lunchbox. Sorry for the typo. Forgot the n. A compact locker that mounts in your existing open carrier.
Old Feb 18, 2018 | 02:22 PM
  #23
Lefet's Avatar
Lefet is on a distinguished road
This is a most informative and enjoyable thread.
Thanks!
Old Feb 19, 2018 | 04:58 PM
  #24
theprofreshonal's Avatar
theprofreshonal is on a distinguished road
+1 for the G80 or Lunchbox Lockers
Stock 4WD Blazer is junk. So bad that I thought mine was not working, turns out it is working, its just terrible in the snow. Like has been said, stock Blazer 4WD is actually 2WD, one in front & one in back. Without real lockers or LSDs, power in an open differential set up goes to the path of least resistance, ie. the wheel with least traction. I know it will be an unpopular opinion, & I do love my GMC Jimmy but it really has the worst stock 4WD system I have come across, just my $0.02.
Old Feb 20, 2018 | 01:33 PM
  #25
Rusty Nuts's Avatar
If the tires aren't made to grip ice and snow, they won't grip ice and snow. My 2nd gen had a good set of off road tires when I got it but they did nothing but spin on snow. A good set of all season tires has made all the difference. Even with a one wheel peel it's very capable with the right tires.
Old Feb 22, 2018 | 05:32 AM
  #26
98 4x4's Avatar
98 4x4 is on a distinguished road
Originally Posted by man0steel
Become familiar with the vacuum system and take a couple of feet of vacuum line and a couple of connectors with you.
great advice there!
Old Feb 22, 2018 | 10:20 AM
  #27
Originally Posted by 98 4x4
great advice there!
It is so easy to swap out these lines and so inexpensive, I'd suggest replacing them as a quick afternoon project when it gets warm enough to do so. If you have a 4-button system, you don't even have to get under the truck to do it.
Old Feb 24, 2018 | 06:57 AM
  #28
LannyL81's Avatar
Have already replaced all the vacuum lines and yeah....just under the hood for me.
Tires are "everything!" Speaking of which....I am just about due for a new set.
Did my first trail drive last weekend. No problems other than thought the Blazer was going to be shaken apart due to all the ripples in the trail. Was about an hour long due to the ripples as I was going pretty slow. But t'was my first "high clearance vehicles only" trail...the longest period I have ever kept the 4wd on...although really did not need it. This was more of a trial than a real trip.
Old Feb 24, 2018 | 04:48 PM
  #29
newguy's Avatar
I`vw always believed it was a good idea to activate your 4wd every month or so to keep things moving and keep the transaxle lubricated. Hey whether or not you if its working!
Old Feb 27, 2018 | 09:10 PM
  #30
LannyL81's Avatar
Yeah...I thought so too for a long time but then I thought I read/determined that everything is always turning (when in motion of course) and the only difference is that the T-case is not being driven by transmission/engine....I stopped doing a monthly 4wd engagement.
Correct me if I am wrong here.
