Bleeding brakes - 1997 Blazer w/ ABS
Old Nov 7, 2011 | 05:15 PM
Originally Posted by lunghd
....Now if someone would just fab up a simple tool that would activate the proper circuits... surely it doesn't need the entire scan tool's functionality to do that. Bound to be a relatively simple thing to design - trigger circuit A to bleed, trigger circuit B to reset... etc. No diagnostics - just a bleed/reset tool....
Don't look for that to happen any time soon The ABS connection is the same one that OBDII uses and data transfer is done through networking using class II communications. The scan tool accesses the ABS "menu" and sends a command to EBCM to initiate the automated bleed. The EBCM and the PCM communicate and execute the bleed. The automated bleed is "operator interactive" meaning the operator is instructed to apply and hold pressure on the brake pedal during the bleed process. Actually it's quite simple, if you have a bi-directional ABS capable scan tool
Old Aug 10, 2012 | 08:33 PM
darq's Avatar
darq is on a distinguished road
Default Air in brake lines.
Hello, my son acquired a "93". It's very rough but I figured since it ran, it would be an ok first car. Several dollars later I don't know. The brakes have air in them no matter how much we bleed them. They are firm with the engine off, but very spongy with the engine running.
I am unfamiliar with the ABS system. I understand air might be trapped in it. I see two bleeders on top of the module can I bleed from there with just a tube ?
I've read posts that some have just simply removed them and redone the lines up front. Is this possible and or safe.
No warning or trouble lights come on. When we first got the truck home I "think" there was an ABS light on. I don't see that, even at start up. The battery had gone dead, and finally replaced, so would that clear the light?
Any Ideas ?
Old Aug 11, 2012 | 09:06 AM
abig84's Avatar
ive done it on my 90 fullsize. truck stops way better. my 93 s10 i just unplugged the abs and cut all the wire and it stops fine. another case of spongy brakes may be frozen caliper, caliper pins or out of adjustment rear brakes
no different then the older cars with no abs
Old Mar 17, 2013 | 09:49 AM
Frank Pino Sr.'s Avatar
Frank Pino Sr. is on a distinguished road
does a 1997 chevy blazer have a DBC-7 abs system?
toms2000blazer
Jul 26, 2012 04:46 PM
Chic_Bowdrie
17
Apr 3, 2012 10:16 PM
mikede123
Sep 20, 2011 11:32 AM
flamez2647
Jul 28, 2009 09:40 PM
chvygirl84
Nov 20, 2008 08:45 AM
