Blend Door Troubles
Old Sep 4, 2012 | 12:04 AM
BigDoug's Avatar
BigDoug is on a distinguished road
Default Blend Door Troubles
Thanks to all of your help from this site, so far I have kept my 1998 GMC Jimmy SLT 4x4 running for two years. Now at 124,000 miles. I have a problem with my blend door yet to be resolved.
I have read just about every thread on the Blend Door issue as my heat has been stuck on now for 2 weeks. I tried to jump the car after the battery died with cables reversed (long weekend). I fixed the cables and jumped the jimmy and ever since then the blend door is stuck on heat.
I have replaced the actuator motor ($140) and tried 3 replacement control units from the junk yard ($75). They all 3 perform exactly the same. I checked the battery and its good but replaced the alternator ($150). I have reset the computer several times and had a local shop check it out ($75) with the same suggestions. Replace actuator motor and dash controls.
My mechanic hooked up his GM computer and tried checking the program as well. ($100) When he sent the command to move the blend door he gets an error 255 (system overload I think). His only suggestion is to start replacing electrical components starting with the body computer.
Any ideas? I have found no burnt wires, no blown fuses and no burnt smell. Something in the system is sending the command to the blend door to stay on heat and I am out of ideas, money and patience. Thanks.
Kidkaos70
Apr 20, 2011 11:35 PM
stickemdano
Nov 14, 2009 11:13 AM
megaroos_00
Aug 11, 2008 07:39 AM
sprindl
Mar 10, 2008 05:58 PM
whiskey24
Oct 26, 2007 08:29 PM
