blinkers not working
my blinkers wont work. idk what could be the proplem the fuse is straight, i went to turn them on this morning on the highway and noticed it was not comeing on on the dash so when i was at a red light i turned them on and noticed they were not comeing on i was useing the car in front as a mirror.
RE: blinkers not working
fixed them.
Can you please enlighten us...what did you do to fix them?
This is kinda along the same lines as what i have going on. During the day the blinkers work fine, at night when i turn on the headlights both turn indicators light up and the blinkers stay totally functional. Is this normal? i can't figure out how to insert a picture here but i have a picture as well. my mechanic looked at it and said it was the alarm causing a ground and showed me what wire, so i took it to the alarm guy he cut the wire out and it still did it. BTW is a 1996 Jimmy, it's not terribly important but I just bought the truck with 133k for $500 but it's only a 2wd.
ok i put the picture in my profile.
need help still. thanks
i took the fuse out cleaned in put it back in checked if everything still worked and they worked all i did was take the fuse out and put it back in.
athens61
11-28-2006 10:24 PM
