Blowing fuse for tiftgate,inter lights,mirrors......
Old Sep 19, 2007 | 09:17 AM
schums's Avatar
schums is an unknown quantity at this point
Default Blowing fuse for tiftgate,inter lights,mirrors......
I have looked through the pages and have not found anything that will really help me. I have a 96 Jimmy SLS 4 door, my fuse(courtesy fuse slot 2) keeps blowing when ever i put in a new fuse in. This fuse is for the liftgate, inter lights, mirrors, power seats, horn, cig liter. I have torn apart every panel to try and find the problem. I thought I fixed it once by moving some stuff around in the tailgate though about a month later it started up again. I am thinking it is from a dead short somewhere from the the tailgate to the fuse box under the dash. I have tryed to trouble shoot it by disconnecting everything then connecting one at a time nothing blew until I put everything back together that hit the liftglass release a couple of times. If anyone else has had this problem or has any ideas i would be grateful i miss using my tailgate and liftglass, Thanks a lot
Old Sep 19, 2007 | 05:27 PM
Default RE: Blowing fuse for tiftgate,inter lights,mirrors......
lastcoupe, had made a suggestion in another thread quite similar to this. His suggestion was to check the wiring under the seat for shorts. This is a quite common occurance. Might want to start there and see how things go.
Good luck!
Old Sep 19, 2007 | 06:02 PM
schums's Avatar
Thanks Kyle, come to think that think that is on place i did not check when i was troubleshooting. I will look into it he soon and get back to you on it.
Old Sep 22, 2007 | 05:12 PM
schums's Avatar
Yah Kyle thanks alot the cig lighter was the problem took me 5 min to do well talking on the phone haha thanks again i like using my tailgate again and inter lights i can see again thanks
Old Sep 22, 2007 | 06:02 PM
Great! Glad I could help!! Hopefully it doesn't happen again and was just a fluke. If you find that you are continuously blowing fuses, you may have a fault in the wiring somewhere that will need to be found and fixed to keep from having bad things happen...
AustinBlazer
Jun 4, 2013 10:35 AM
Hank3band
Sep 20, 2011 09:08 AM
X Gixxer 1000 X
17
Aug 30, 2011 02:11 PM
higgy
Nov 29, 2009 03:09 PM
fresno99
Jul 31, 2009 08:12 PM
