blowing heat at high speed
Old Aug 12, 2012 | 11:13 PM
Blazing96's Avatar
Blazing96 is on a distinguished road
Default blowing heat at high speed
Hi.
I have a 2002 Blazer 4x4 and need help with a problem with the heating. It pushes hot air out of the foot heaters. It only does this tho at speeds of about 30 mph or above. anything below that and no air comes out. Everything works as it should and the problem goes away when the ac is on.
I hope I didn't confuse you too much and thanks for the help!
Old Aug 13, 2012 | 12:21 AM
Rottidog's Avatar
2 things come to mind - vacuum lines are pooched &/or the actuator door in the cab.
I doubt things are working as they should because it sounds like a vacuum line has a leak & your controls aren't capable of contoling the HVAC options.
You should have a vacuum box inside the DS fenderwell & a line leading to it.
Check all the vacuum lines from the manifold to the brake booster & anything they're connected to.
As for the door actuator in the HVAC search around in here for ideas.
Pipewrench Dale
Nov 10, 2014 06:16 PM
jdub9000
Jul 22, 2013 07:58 AM
erik102207
Nov 19, 2007 09:31 PM
cpaptogo
Mar 30, 2006 09:30 PM
