boggs down !
Old Aug 21, 2008 | 10:38 AM
goldie's Avatar
goldie is an unknown quantity at this point
Default boggs down !
I have a 1999 4.3 liter 4wd. Starts great, but when I back it out of the garage and put it in drive, I give it alittle accellerater and it bogs down for a few seconds as if it's getting no gas. After that it picks back up and is fine. It usually won't do this anymore that day I can start it - take off, and it's fine. Any ideas ?
Old Aug 21, 2008 | 10:41 AM
Default RE: boggs down !
What have you done to try to correct this? I would start by cleaning the EGR valve (replace the gasket with an aftermarket gasket which has a screen on the inlet side) as well as clean the MAF sensor. Either of these things, when dirty, can cause an off idle bog. I'd bet that the MAF sensor is the cause of your problem.
Old Aug 21, 2008 | 06:10 PM
goldie's Avatar
I've already put on a new egr valve and gasket. I'll follow your advice and go for the maf next.
I hate to be a pest but what is the best way to clean it ? ( I'm so dumb)
Old Aug 21, 2008 | 09:22 PM
HOW-TO: MAF Sensor Cleaning
Old Aug 25, 2008 | 09:59 AM
goldie's Avatar
I hope you see this post "swartlkk"! Thanks a million for the tip on cleaning my maf sensor. I did it over the week end and it seems to have fixed the problem. Once again - a BIG THANK YOU!
Old Aug 25, 2008 | 11:19 AM
I am glad you were able to find a solution to your problem!
Jared Miller
Jun 17, 2012 03:07 PM
2000jimmbo4x4
Sep 14, 2010 08:51 PM
Kendo
Sep 22, 2009 11:12 AM
Fat_Phil
Feb 20, 2009 10:48 PM
99 Blazer 4x4
Sep 6, 2007 05:06 PM
